Keep tracing backwards from your pump and see when you gain your 12vdc power, perhaps issue with relay or FP resistor.
Also is there power at the b+ terminal to ground?
Do you ahve good continuity from Fp to your fuel pump connector that you said you are not getting power.
If you pulled fuses, check for any corrosion on either the spades on fuse or the connections on fuse block.
There are other things, but that is a start...
