Fuel pump switch...?
ToyotaSupra
Shawn
Dec 12, 2009
59
Fond du Lac
my fuel pump and injectors dont turn on, i cant figure it out, is it possible for me to wire a switch to turn them on (i know how) when i run it and off when im not, (i mean is it bad or anything for the pump)
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Wiring your fuel pump on a switch *can* be done, of course, but it's not a good idea.
Furthermore, if your injectors aren't firing, then supplying them with fuel isn't going to help. Unless you wire each injector to a switch, and train your trunk monkey to flip them, in sequence, at speeds of up to 54 times per second. ;)
