fuel pump not kicking on
mk3supra
231
Decatur, IL
www.supramania.com
I jumped fp and +b in the diag box with the key on and my fuel pump did not come on. I have checked the efi fuse and the wiring and it is all fine. Is this a sure sign of my fuel pump being bad?
theres a panel under the wood part next to the spare tire. remove that and you will see the wiring for the fuel pump and sender. put power and ground to the pump and if dont hear it you need a new pump.
