Fuel pump hanger question
primercrx
59
Lexington, South Carolina
All,
When I was attempting to install the fuel pump hanger with the Walbro on it, I managed to crack off the connection to the power wire where it looks like a rivet at the top. Here is a picture of what I am referring to. Would it be possible to Dremel this off and install a new ring terminal with a nut and bolt, or could I simply just jumper the power wire to the top of the hanger where the body harness comes into play at? For clarification, my thumb is pointed towards said riveted connection. Any input would be greatly appreciated. Also, disregard the "upgrade" list..... fuel pump hanger.jpg
primercrx
59
Is there a "proper" way of removing a rivet? Would a dremel be too abrasive if I did in fact have to cut/dremel off the old rivet? Also, I have the hanger itself still attached to the car. The gas tank is under my carport at the moment. Was having an issue with the hanger lining back up, and I think that is when I accidentally broke it off.
