ok so ive been searching everywere and cant find any similar problems to mine here. i have a 91 7mgte and after driving the car for anywere from 5min to an hr the ful pump will randomly shut off. upon trying to restart it when you let off the key after trying to crank it the circuit opening relay spazzes out and just clicks rappidly. im able to jump the test terminals and start the car. usully if i go to startit the next day it will fire right up. only reacent mods i have done are a walbro 255 pump but i had it in for a few months prior to this happening. most recent was recalibrating the tps. im wondering if it could be a tps fault seeing as how the relay cuts when no throttle signal is there at terminal (fn) accomponied with the afm no airflow. No fault cods pop up. i considered a relay but that relay is 70 buck kinda pricy just to throw parts. Please help.
