fuel pulsation damper removal
S
Slow Poopra 7MGTE
Guest
hey whats up guys, i was wondering if anyone knew where to buy a fuel pulsation damper removal line. i know AAP motor sports use to sell them but i am assuming they are not in buisness anymore seeing that the store part of there website says it is permanatly closed, any help appreciated. and maybe a afpr with lines for a decent price,i wanted the aap stuff because i dont have alot of money and they USE to have the "budget" parts but w/e works i found a nice kit on 935 for 280.00
8,898
So for those that have removed the injector(pulsation) damper, what are the ways to counter the gaps in pressure? Is the stock pump up to the task, or is that AFPR as mentioned above the minimum needed with an upgraded pump?
Adjuster
I ran my car with the stock FPR removed, and the Areomotive one on there for quite a while. (No problems.)
Then upgraded to a Walbro fuel pump, bypassed the resistor so the fuel pump has full voltage all the time. (Made it loud at idle.)
The final mod was to change out the FPD (On the back of the rail, near the EGR location.) This seemed to make NO difference at all, but did clean up the engine bay, and simplified the hose routing.
Mine goes straight from the fuel supply hard pipe, to AN stainless line, up to a 180 swivel seal AN fitting, and a AN adapter that uses the stock threads on the fuel rail. (It is a BSP type adapter with an O-ring that seals up the fitting.) Same type of fitting is used at the front of the rail to adapt the Areomotive AFPR and stainless line there. (Everything is AN but the cold start injector which still uses the stock banjo fittings/hose etc.)
No problems so far, but with the fuel pressure regulator mounted to the left strut tower, you can hear the fuel pump/pressure through the body of the car. (Sounds like a thumping noise at idle, but you can't hear it over the car sounds beyond that.)
shaeff
Kurt is FTMFW x2!!!!
11
Around
Stretch said:
I believe JBL sells the dampner kit on his website if I'm not mistaken.
eric
you, sir, are correct. :)
-shaeff
lagged
1991 1JZ
new rochelle
i used aeroquip lines and fittings. the line is resting on the brake booster and i can hear some injector noise coming in to the cabin.
