How long should the fuel system maintain pressure after the car has been turned off, mine starts to drop as soon as I turn the car off.
mrnickleye said:You could try putting 2 bottles of TECHRON into a full tank of gas, and run it down to 1/4 full. This may help by cleaning out the injectors and check valve.
jdub said:The TRSM spec is 21 psi or more for 5 minutes after the engine is shut off.
http://www.cygnusx1.net/supra/library/TSRM/fi/FI_073.html
