fuel pressure remain after engine off?
mkIIIman089
Ohio
Hey guys, quick Q and this may seem obvious but I think better safe then sorry.
Tonight I want to tap for my FP guage and I have all the stuff i need, only thing is I want to make sure that somehow fuel pressure between the pump and FPR doesn't get trapped in under pressure. So that when I tap it fuel doesn't spray everywhere.
Thanks!
mkIIIman089
Ohio
Okay, I figured even if it was it wouldn't be too bad like you said ck.
Thanks for the quick reply guys!
Later.
mkIIIman089
Ohio
mmk, so I cracked the banjo bolt that feeds the FPD from the tank... and there was not a pound of pressure in there. I twisted it probably like 3-4 turns out and no pressure to be found.
So now, is there something wrong? Or is it supposed to bleed off within two hours of driving?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
The system should retain rest pressure after the engine is shutdown. It should drop no more than 5 psi in 10 minutes. It'll likely be gone after two hours though.
Btw, you can relieve rest pressure a couple of ways to prevent spillage. 1) Remove the fuel pump relay/resistor connector and let the engine die. 2) If you have a hand vac pump (like a MytieVac) apply 25 inches to the fuel regulator for about 45 seconds with the engine off. You should remove the gas cap too.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Crack the bolt at the cold start injector. Its right up top, and the pressure will drop off in .02 tenths of a second. :biglaugh: and you won't even get squirted in the eye. :biglaugh:
mkIIIman089
Ohio
Cool, thanks guys! I got my guage set up finally (been like 3 months since I bought the thing) and everything seems to be working properly. Kind of neat to see how much it actually changes just going up hills and stuff :)
