I have read stock setting is 35-40 PSI. I just put in an aftermarket adjustable one. I have all the mods plus 550 injectors, what should I set my pressure to run at for best performance? Also, when you check are you suppose to have the vacume line connected or disconnected? Having the line connected you get lower pressure then if its pluged in. So what PSI should I run it at and when I check it do I unplug vacume line?
