Scenario:
-Vehicle: 1992 N/A Supra
-Engine/Harness/ECU: 1991 7MGTE swap
-Turbo: Modified CT-26
-Air Flow Metering Device: MAFT (not PRO) w/ 3.5" GM MAF
-Fuel: Aeromotive AFPR, Walbro 255lph, Precision 550cc injectors, Driftmotion Fuel Damper Bypass and AFPR kits installed. Fuel pressure was set to 40psi base with Fp and +B jumped.
-Ignition: NGK BKR6E Spark Plugs gapped to .028" Issue is present with both Stock Ignition coils and wires, as well as 2JZ VVTi Coils and wires (Tookwik mod). Igniter ground mod has been performed.
-Timing: Set at 10* following TSRM. The CPS wiring is all good. I replaced the harness side connector and checked the wires/connector on the CPS and they are good as well.
-Knock sensors rewired with RG-6 coax cable. Sensors and wire have been tested and are good.
-No Codes are Present.
Issue:
The car drives GREAT in all throttle/load conditions, in and out of boost, with two exceptions:
*It breaks up terribly ONLY between 3450 and 3550 RPM. It does this whether there is no load (free revving), or load applied; as well as in and out of boost. The only difference between low load/no boost and greater load/in boost is that when there is little-to-no load applied the engine breaks up bad enough that it won't carry over past that ~3500 RPM threshold. Conversely, while under load/boost/accelerating at a greater rate, it momentarily breaks up at that point, but is hardly noticable and is able to pass the threshold due to momentum of the engine with the car accelerating in gear. I have not yet wired my wideband O2, so I haven't determined if it's a lean or rich condition; however, due to the sound (sounds like it's on a two step when free revving to 3500) and consistency of occurrence, I believe it is some sort of computer controlled ignition issue.
**Secondly, the warm idle is far too low at approximately 400-450 RPM. Because it idles so low, the car will die out nearly every time the clutch is depressed and the revs are allowed to drop without modulation of the throttle. If I'm careful with the throttle, I can get it to hold an idle, but it is at that very low point.
Diagnostics Performed:
I calibrated and tested the TPS according to the TSRM and JSeaman's writeup (http://www.supramania.com/forums/sho...osition+sensor), and everything was in spec with the exception of one reading. Resistance measured between E2 and EDL are supposedto be 2.3k ohms with a 50mm feeler gauge between the throttle and set screw; my reading was ~12 ohms.
I've been reading VF (Vf1 > volt meter > ground) and while adjustments with the MAFT create physical/audible changes in the way the engine runs, the VF signal seems to be unaffected. From my observations, the VF signal has five readings: 0.0xx volts, 1.0xx volts, 2.2xx volts, 3.5xx volts, and 4.9xx volts. The readings vary across this range, most commonly when either under throttle or lifting completely (goes from 2.2-4.9 while under throttle to 0.0xx when completely off the throttle). At idle, the reading has been any one of those five. Again, adjusting the Idle dial on the MAFT seems to change the way the engine runs, however the adjustments don't seem to have any direct effect on the Vf readings.
I'll update the thread as I progress through my diagnostics, but any and all help would be greatly appreciated.
-Chris
Issue:
-Chris
