Fuel pressure check
WindTunnelJimbo
Bay Aera
I did a search and could not find this.
I need to check my stock 7M-GTE fuel pressure, but I have never done it before and I don’t know what fittings are needed. I checked the TSRM and I did not see a spec. for fitting size. Also what is a good setup to buy for this?
Any advice will be appreciated.
Thanks,
Jim
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Jim: I have the fittings to convert the system to a AFPR and fuel pulsation dampner removal. Besides that IIRC you are to remove the bolt that goes into the cold start injector and attach a hight pressure hose and gauge to check for fuel pressure.
Im not sure what the size is on the CSI though.
