fuel issues
mista_sup
211
atlanta
just did a na to turbo swap, will my na feul pump causs the car to run funny or will it be fine untill i make the change???:1zhelp:
car idals for a few then cuts off????
lost:1zhelp: :1zhelp: :1zhelp: :1zhelp:
dbsupra90
toonar
indiucky
run funny how? i wouldnt want to run big boost on a na fuel pump. but just crusing around, idle, etc it will be fine.
how long is "a few"?
mista_sup
211
atlanta
it hesitates, when taking off from a stop u have to almost dump the gas for it to move. it idles fine for about ten min. them it will cut off.
TRACKMKIII
464
Atlanta,GA
I am not 100% but I thought NA and turbo fuel pump were the same. I am swapping mine out for a Walbro unit but I thought the stock pump was the same for both models.
TRACKMKIII
464
Atlanta,GA
I don't think it is fuel realted either. I think it has something to with the ignition system. We were im such a rush when doing the swap and the spark plugs weren't in stock so i think the old plugs may be fouled and we also need to check the timing.
