Fuel Injectors not firing
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
Ok i swapped the motor in my car and it will crank but not start. If i pour some gas in the intake and try it will start and run for a few seconds then die. I disconnected the fuel coupler and the pump is working. So i assume that the injectors are not working. I am not sure where to start. I pulled the fuse for the EFI and the relay and replaced it still not working i did the same with the fuses under the dash. What should i try next??????:1zhelp:
