Fuel injectors are barely pulsing.
bigboostinmk3
15
ohio
We put a noid light on the injectors and cranked it is barely lighting up. I have swapped out ecus so I know that is not the problem. Could it be a bad ground somewhere? What would cause this issue?? Oh and my security light stays on when I turn the key on and when cranking the car all the time? Is this normal for an 89 mk3?
