Fuel Injector Adapter
Hey, I just bought some Precision 550 fuel injectors. They came with their own pigtails. So my question is, is there a way I can buy the sensor that is on the stock fuel injector. I'm talking about the connector that is on the fuel injector that the connector from the wire harness connects too. (Sounds confusing) Reason I want this is because I don't want to cut my wire harness. I'm plan on making something like this. http://www.ebay.com/itm/LQ4-LQ9-4-8...Parts_Accessories&hash=item27d823af47&vxp=mtr
This way I can use the Precision 550 fuel injectors without having to splice into my wire harness. Also another question, can I just buy what Im trying to make? Thanks
7M4EVR
695
fah, fah away
Wonder if u coud just buy some used stock injectors and take those off the injectors somehow?...then you would just have to wire those to the precision pig tails...im sure this has been thought of before tho, so maybe someone does make pigtail adapters already?
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Sensor? I think you mean connector. Anyway, they are sold all over the place. You probably have EV1 connectors on the 550s, so in Ebay, you can search for
FUEL INJECTOR ADAPTER HARNESS EV1 TO DENSO
You might also have EV6 connectors or something else, so double check the pictures before buying.
