Fuel Door
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Whats the best way to adjust the latch for the fuel door, I'm thinking it is behind the release for the fuel door.:1zhelp:
mkiiSupraMan18
Needs a new username...
United States
Just shove a garage door opener under the lever, grab a quarter or something to bring with you and pry that sucker open. That's how I roll.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
IIRC there's a slight adjustment at the fuel door side.
If there's not, and the cable won't pull far enough, just buy a new cable. Chances are it's stretched pretty far from someone pulling on it too hard, too often.
Draken
57
michigan
my cable was streched on mine...well...still is really...
I ended up taking a double cut bastard file to the end of the nubbin that sticks into the slot on the fuel door so that the cable doesn't have to be pulled as far
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
thx, i think i will try the adjustment at the door then if that doesn't work i think i will just cut the wire and reconnect it ;)
aggie08281
supra junkie
Feb 4, 2006
57
Houston
thats what im talking about, i usually just fold the mat under the lever
