Fuel cut off
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
i have a problem i keep hiting fuel cut off as soon as i hit boost..for example in for gear at like 3000rpms i hit boost it fallso n its face any ideas ?
5l_eater
Jan 17, 2007
258
Maryland
well its not a boost leak any other ideas im thinkin it might be a fuel problem maybe the injectors or could it be the ecu cause it to run in default mode makine it misfire and run lean and rich ?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Did you do a leak test? Did you check every coupler from the turbo to the IC to the TB?
Reason I ask, you didn't tell us how you know it's not a boost leak (sure sounds like it to me).
Also, did you pull ECU codes?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Build a tester.
Go over the intercooler piping once again. If it all looks fine, tighten up the clamps, every one of them, one or more may be loose, causing you to leak boost between the rubber coupler and the plastic piping, but I would hazard a guess and say that the leak is probably due to a tear or hole in one of the couplers if it's cutting out around 3K RPM.
