fuel cut off
SupraBiscuit
10
Mississippi
When I turn up the boost I dont hit fuel cut off but when I shift my engine shutters like fuel cut off and then runs fine. Any chance thats my Bov not allowing enough pressure out before I start back in gear?
Thanks
Brian
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
What kind of bov? If its venting to atmosphere then the engine isnt seeing the air that measured earlier, therefore its really rich will make it almost die or die sometimes.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
where does your boost controller get its boost reading from? in my experience, if you use the manifold boost instead of the turbo nipple for the boost controller, it spikes between shifts.
