I have some in depth questions about fuel cut, not about removing it but more of how it functions. Im not sure if I should post this here or in the fuel cut discussion but here it is. I have a 2jzge with 7mgte ecu, harness, etc etc that i just got running in my datsun, wired in fairly minimally. I would actually like to have a functioning fuel cut if I can. It appears in the wiring diagrams that the fuel cut wire just activates the circuit opening relay to kill injector power. My fc wire is currently not run to anything so I was wondering if anyone knows if there would be any running side effects besides the ecu not being able to fuel cut. In addition, would I be able to run my fc wire to hypothetically a separate relay to interrupt the ignitors fire signal or something creating a safer ignition cut when too much boost is hit?
Thanks in advance for input
