Ok, i baught this motor with every intention of putting it in my car. Instead i baught a JZA70 for parts and went with the 1JZ-GTE. Now ive ot this 2J sitting at my buddys shop. It is not fully assembled. I preped it for install by taking off the power steering pump, ac pump, stock twins and all the brackets for the above listed. I also pulled the valve covers and painted them. I did not throw anything away, except old gaskets that are not reusable.
It being from an Aristo, it came with the front sump oil pan, which as most of you know is useless if you want to put this motor in a supra. Long story short it took me over 3 months to get the proper oil pan from Nagasaki Motors in Richmond, who i recommend no one ever deals with. Even after i got the proper mid-sump oil pan, they did not give me all the bolts to even put the new oil pan on. They will not take responsability for their mistakes, and all around have extreamly POOR customer service.
The motor will come with the following:
- Any and All items that i removed from the motor (minus gaskets that were thrown out)
- Wiring harness, good for parts only, as it was cut when i purchased the motor
- New Valve Cover Gaskets (from Toyota)
- New Exhuast Gaskets (from Toyota)
- New Valve seals (toyota)
- Front & Rear Main Seals
- Single Turbo Exhuast Manifold w/T4 flange
- Mid sump oil pan WITHOUT oil pan bolts
There might be more that i have, im not quite sure what eles i collected. I paid $2000 for the motor and harness and ECU. I never received the ECU from Nagasaki Motors.
Im asking $1800 for everything. I spent almost $600 dollars at the Toyota Dealership on gaskets and seals for the motor.
