front wheel play
Finnon
701
South Shields, Tyne & Wear ENGLAND
I have slight play in my left side front wheel (passenger side for me as im in the uk) the play is evident only if i hold the top and bottom part of the wheel. no side to side play at all. could this be the wheel bearing? or is it more likely to be the top ball joint? i couldnt see any movement in the bottom ball joint.
cheers
MmmBoost
DDS Performance
upper or lower ball joint for sure. try putting a pry bar under the wheel and pry up while looking under the car. that will usually let you see the lower ball joint move if it is going to. the upper ball joint is hard to diagnose, because the springing action of the bushings keep tension on it. you might also try looking under the car with someone else shaking the wheel for you.
