i saw a picture of a Mkiii with the front end converted to a toyota chaser...and i was researching on it, i found out...which some if not most of you know that, they share the same engine as the twin turbo model mkiii in japan, so maybe i was thinking that it should be possicble to change the front...and i bet some of you reading this are saying, why would you do such a thing? well because i may want something different. so yeah i just want to know if its a play and play kind of deal...because if its the same then it should be easy right?
thanks
thanks
