I went to replace it, and rushed the job and forgot a crucial thing, is this caliper a slider meaning the topmost hole of the caliper does not have a bolt going in it?? just the bottom right?? only reason I ask is it seemed odd. and when I bled the brakes the top of the caliper still wanted to be loose, pisses me off a little. I have 2 long bolts as well, the one at the bottom is screwed in along with the slider plate, but the top has a cap on it so I'm not sure if you take the cap off and put the long bolt thru it, I guess I messed up here LOL
