Considering that the 2JZGTE (one T man, its not a Nissan) was made only with a V-160 6 speed manual and a A340E 4 speed auto you may be looking for a long time. However should you wish to have a 5 speed you have basically two alternatives. Either get the 1JZ bell housing and go with the R154 5 speed from the A70 turbo chasis or the 2JZGE W58 5 speed from both the NA A70 and A80 chasis. Which if you are going to put the 2JZGTE into a A70 chasis you will likely want to go with the R154 as you will have a much easier time finding a drive shaft to facilitate the swap as the standard 5 speed turbo driveshaft should work for the swap.
