are you talking the front bumper cover,or the metal bumper itself? the cover has a shit load of bolts and nuts holding it on. fun little process that involves removing of the 2 grill inserts,side marker lights,side marker trim,and turn signals. all of it has to be done carefully or the old plastic will break.you have to remove the bottom plastic pieces,the center deflector,then the right side and left pieces just to get to the fsteners that hold the fender arches in.THEN there are about 4-5 in front of the radiator where the horn is that are are a bitch if you don't have a swivel deep socket(about a 10 mm i think) funfunfun
