Front Bumper Removal
80083r
I was going to make one when i took mine off... but it took me a week of evenings.
You will need to take the plastic shrouds out of both from wheels to get at the bolts under there - that's the ones that got me - the rest are fairly easy to spot.
Sep 19, 2011
510
Des Moines, IA
If you just want to get the bumper and bumper cover off easily, undo the two bolts in the wheel well that screws the bumper to the fender. take off the grills and take out the turn signals, then unplug fog lights, undo the two bolts that attach the bumper to the frame, and pull it off. It is really simple. Much easier than taking off the bumper cover.
I did it this way when I installed my intercooler, I know people have done it differently, but I had no problems doing it this way.
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
Taking the bumper support off with the cover is lots easier than taking just the cover off, lessons learned :rolleyes:
Sent From My HTC One S using Tapatalk 2
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
good stuff.
Sep 19, 2011
510
Des Moines, IA
HMNGSupraMKIII;1899807 said:
when you say undo the two bolts that attach the bumper to the frame, do you mean the two big bolts under the car?
Yes, you will undo the two nuts that are on the bottom side of the frame rails, then pull out both of the big bolts that go all the way through the frame rail and attach to those two nuts you just removed. They are kind of a pain to get out and put back in the frame rail, but its easily done.
Beals
JZA70 TT-R
Feb 3, 2009
591
Alberta, Canada
I got the front bumper cover pretty much off except for one bolt right under the front nose piece, I'm guessing that it's a frame support bolt but the only way I see of getting at it is removing the stock intercooler.. mind you I do plan on doing this bc I'm putting a driftmotion intercooler on I just thought it would be easier to do after the front bumper was ripped off.
