Alright so I've been doing some research on what exactly is happening but can't come up with a specific answer in my case. I just rebuilt my 7mgTe and it smokes quite a bit out of the tailpipe. I don't notice a blue "tint", it looks white to me. I'm wondering how long it takes for the piston rings to seat and also could this be caused my a bad turbo? The turbo I have no seems fine, no shaft play etc.. but also I my boost gauge jumps all the way past 8+ psi when I turn the key to the "on" position and while its running but drops to the bottom when car is off (not sure if gauge is messed up or not). Any help would be great with this matter. Also my car currently idles high because my isc (not sure if this matters for rebuild, I heard it supposed to run for around 30 min at idle then change oil).
Thanks guys
Thanks guys
