Okay just lettin everyone know I did some searching the other night found some sweet ass mods for FREE!
Poor mans fuel pump upgrade
12 Volt fuel pump mod - TAKES ABOUT A MINUTE TO DO!! My car has much better responce and some more midend power after this mod, unplug the silver box on passenger side fender (2 wire connector) jumper the wires into themselfs eliminating the silver box or just tie them together.
Poor mans performance suspension
TEMS Super Stiff mod - You can make it so that in Sport mode you get 3 bars all the time, its great. By the battery theres a big fuse box beside that is the diagnosis connector, peel some of the coating back on the bottom wire loom runing into the connector, jump purple and brown together
Poor mans LSD upgrade
LSD LOCKUP!!
Redline 75W 90 NS for NO SLIP!!
Drain oil, Add a bottle of this and then make your own slip ratio using normal rear end oil, make it grab hard with high level of NS or make it softer with more rear end oil id start with all NS take for a test run and move from there.
There are a bunch more but thease are the ones I have done so far ill keep you posted...
LSD LOCKUP!!
