I just finished installing my new Walbro fuel pump and AFPR in my car. I set the regulator up using the bypass jumpers in the diag box (B+ and Fp) at 38psi. Next I started the car and double checked it with the vacuum line disconnected and plugged. As soon as I connect the vacuum line the pressure drops to around 28psi. I thought the regulator should maintain the pressure at 38 which is where I originally set it. Is this correct? Oh, and btw I still have the stock 440's in place.
I'm just a little concerned since I don't have electronics installed yet to monitor the AFR (the only thing I have right now is an autometer AFR gauge) and don't want to lean out my engine.
