fp AND b+ damn near melt the paperclip
Status
Not open for further replies.
RIPDOTCOM
157
Tallahassee, FL
I picked up a 86.5 today and cant get it started. i did the Fuel pump jumper test and the paperclip damn near burned my finger off. Think the fuel pump is dead? I hear a whirring but its coming from under the hood.
Supracentral
10
The fuel pump should not pull enough amps to heat a paperclip. I'd say you have a short, or a bad pump.
Try to track down that sound under the hood. You can sometimes hear the fuel flowing through the rail, but a "whirring"? That seems odd as well.
Are you certain somone hasn't added some cheapo universal inline pump somwhere?
RIPDOTCOM
157
Tallahassee, FL
I bought a new fuel pump tonite, im sure thats it.
malloynx
NC
the only thing that will cause that paperclip to get hot is not enough resistance. your wiring is jacked.
malloynx
NC
it could be the pump
you need to check the ohms on the pump and the wiring and see if it is in spec.
i will say this,. denso makes a really good pump and they rarely fail.
walbro is another story
RIPDOTCOM
157
Tallahassee, FL
Cool I picked up a Denso. My MKII had the fuel pump go on it. I will put it in tomorrow but I dont think thats why its not starting. I will post a new thread after its installed.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
I have NOOOO idea what you guys are smoking.. but a paperclip WILL get hot if you jumper it in the diagnostic block. Of course it depends upon what size of paper clip you use. I use a small one so it fits easily into the jumper cavity. it also depends on how long you leave it in there.
There shoudl be whirring in the tank.. and you should hear fuel flowing thru the lines. Pretty easy to hear. You can grab the ruber return line and you'll feel the fuel flowing thru it.
I would say you've got other problems aside from the fuel pump.
shaeff
Kurt is FTMFW x2!!!!
10
Around
yeah, when i tested my fuel pump, i had the exact same experience as al just posted. paperclip got hot, (heard the wallypump like crazy!) and heard/felt the fuel flowing.
-shaeff
Shawndude
Van BC
The shorter and thicker the paper clip, the less it will heat up. Even on my dead stock fuel system, a wimpy paper clip will get pretty hot. A thicker one won't. The whirring under the hood is the pressure regulator oscillating and is normal.
Supracentral
10
Yea, I guess that's probably it - I've only used a paperclip once or twice and they have been very large ones - generally I use a purpose made jumper wire that I keep in my tools.
Status
