forged engine the choices
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
so ive had my supra back together for about two weeks now after replacing the head gasket and behold i have blown the head gasket again. so rather then just replacing it again i think that i am going to pull the engine and compleately rebuild with forged pistons, rods and other goodies. my goal with this car is to eventually see 600 hp. so with that i would like to know the pros and cons of different brand of forged rods, pistons, and bearings. thanks for any help
spoolint78
Representing T.O
T.O
i don't really know of anyone downfall of aftermarket pistons/ rods for the 7m.
all are good.
Just get a good machinest, and triple check all your clearances and you will have a stout motor.
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
same question here. I'm shooting at 400rwhp, and i want to go all forged and maybe in future go for 500-600rwhp. What internals should i get? And what other works need to be carried out in order to hold this power?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Search on here for the guys who are making 600 HP and you'll have a good idea of what you'll need. Most likely they'll have a list of almost every piece that has been put into thier engines ;).
LordLo
242
OR
wow, if it blew in 2 weeks you must have really messed up somewhere along the lines.
F_T_F
C2H5OH
Nov 12, 2006
255
fort fun, colorado
starscream5000 said:
Did you even check to see if the head was warped, or did you just scrape the old HG off and slap a new one on?
no i had the heads resurfaced and made sure that there was no gasket material on the block.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Um.... Supras have only one head for starters ;). Second, you should have had the block and the rear timing plate machined at the same time. That's is most likely why you BHG'd.
