For thoes with 1jz and heaters
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Can I please get a diagrm or a picture and an explination on the hose routing fromt he VSV?
My heater doesnt work. I got super fed up tonight when I went to get gas and i could see out the windshield. It was unplugged, I pugged it in, it made a little difference, but nothing t write home about.
The VSV is bypassed, I wanna see whats up. Or maybe how I can jsut trick it to stay open to give me 100% heat when I turn on the CC, it doesnt even need to give me a fancy reading, jsut pure heat.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
You could route the hose right from the fitting on the head into the heater core and eliminate the need for the valve at all. Keep in mind that Joe's 1J was done before I was doing 1J harnesses, Mike did the harness and there were some accessory items he used to omit like ac and heater.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
There are only two big coolant hoses going into the firewall. There are only two big coolant hoses at the back of the engine.
The drivers side hose on the engine goes to the drivers side heater core pipe. The coolant hose above the turbos at the back goes to the heater core pipe close to the middle of the firewall behind the valve cover.
Big Wang Bandit
Feb 21, 2006
7,551
Ill check it out tomrrow. Moe thinks he found the wire we need to attach on the harness for my heater. He diddnt like the harness too much =/
Hopefully I can get it the correct way.
