For people that are having problems with LED hyper flash in their 86.5-88
leftynridge
401
dayton, ohio
Some people may already know about this web site if so just ignore this post. I'm sure most of you are aware of the the LED hyper flash that accurs when putting LED's into your supra. IF your having this problem I found a web site called autolumination.com. They have a green toyota flasher that fits perfect in replace of the old one for your 86.5-88. The part number even begins with 81980 which is the same as the one that is currently in your supra. This item is only 14.99 and is a plug and play item. So for those planning to use load equalizers don't waste for time or money. Not sure if they have one for 89-92 or if this one will even work. But when finding out info on the one that I purchased they were quick to respond to my email. So anyone trying to change your current 1156 bulbs to LED's this is a must to fix the HYPER FLASH!!!
Kota
105
michigan
i ended up with white leds in the front so my turn signals look like strobes
-not that that had anything to do with anything... just my 2 cents
