fog lights in seprate circut
89supra884
170
chicago
i dont no if this would be considered in a seprate circut, but i want to no if there is a way if i can wire my foglights to the stock switch, but have them on when my headlights are off. i have seen it somewhere before on a website, looked it up on google, but cant find it.
anyone......
thanks
BCsupra
Supras 4 Life
Sep 22, 2008
29
Downey, CA
Yes there is a way because my fog light wires were cut when i bought my car and no power was going to them. My brother helped me wire a new set of wires from both my fog lights to the battery and to the switch, so i can turn it on with the car off and the headlights down.
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
You didn't use a relay and a fuse?
di_rosa
never ending project ...
Apr 2, 2005
215
toronto
why not wire up the relay so it'll work when the headlights are off? that's what i did, and i know i'll never fry the switch
shaeff
Kurt is FTMFW x2!!!!
11
Around
By moving the signal wire to power the relay from the low beam circuit to an accessory circuit. ;)
8,898
Said circuits can be the dome light, that is the green light under the dash, parking lights, as some people like, or hardwire to a B+ source. The switch provides the ground to the relay, so you won't have too much current.
And after you do what shaeff suggests, dont' forget to turn them off.
cuel
1,536
Baytown, Texas
Or make sure you wire into one of the fused circuits that only work with the ignition on(like the radio or turn signals) ;)
