What are the technical specs of getting a flywheel resurfaced, what do I need to tell the machine shop?
dbsupra90 said:here you go chris-
To maintain the same distance from the flywheel to the pressure plate (and therefore the same force) the step between the mounting surface for the pressure plate and the flywheel friction surface must be maintained. Therefore, they need to grind at two different depths.
The stepped ring of the flywheel is the mounting point for the plate. That step is .020
