flywheel help
gsxr141
1,158
10
rochester
i recently bought a "fidanza" flywheel from the for sale section because i knew i could get a replacement disc cheap. when it showed up, it was an aasco flywheel. i've searched, but i can't find the disc for it anywhere.
the question is, should i send it back or keep it and try to find the disc? i'm sure if i can find one, it will be more than the $45 fidanza one.
thanks.....kevin
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
Yo dude, whats up. I looked into this quick and it seams that aasco was bought out by unorthodox. HP freaks has unorthodox inserts for $160 but I dont know if they are compatable and they did not list one for a supra. You need the 9.5" OD and 6" ID "heat shield", aasco still has a wbe site but it kinda sucks so you would have to call them. I could make you a cromoly insert for it as you are local and we could just meet up and I could take the old insert to work. give me a call or a PM
Brett
gsxr141
1,158
10
rochester
cool. i found one on ultrarev's website for $125. hopefully i can find one a little cheaper. if not, i'll be giving you a shout.
thanks man.
Another MkIII
697
Chicago
Why don't you get your money back from the seller? If it was sold as a Fidanza and that's not what you received, you could probably get your money back and keep looking for a Fidanza.
-AM3
gsxr141
1,158
10
rochester
i'm pretty sure this one is actually better than the fidanza. the downside is, the insert is a bit more money and harder to find.
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
I took a look at that one for $65 on ebay. CAT seams to be a legit company, small long time running USA shop. Its probbly a great deal and its S.F.I. rated and they seam to do a lot of NHRA stuff. For $65 you could pick that one up and run it and that would give you time to find or have me make a new insert for the aasco one. For that price it never hurts to have a spare quality unit on the shelf.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
I've been driving on one of them for 4 years.
Pretty sure it's the same exact unit, but I paid almost 3x as much back then.
redrocco
QUADCAM
Feb 21, 2007
78
Rochester NY
I looked around on line and read some reviews of cat's parts. They seem to be kinda hit and miss depending on what kind of part and how much of the machining they do vs there china suppliers. $65 is a very good price but I would hate to have a flywheel fail. You might just be better off rebuilding the aasco as they are known to be very good. Or at least they were before unorthodox bought them, lets just hope they don't loose there quality.
toyota kid
19
Los Angeles
can I reuse the oem flywheel bolts on the fidanza flywheel? if not where can I buy ARP flywheel bolts for the fidanza? This is for a 92 NA i will start soon....any input would help thanks
