flow tested stock/spearco/ssutochrome
lintlars
ROOTS RADICALS
Ft.St.John BC
Ok I got my new intercooler (ssautochrome 12x24x4")the other day for the FFIM I will be building soon I was curious how it flowed against my current setup (spearco stock replacment) I also brought along a stock intercooler for comparison to see how bad it really is these tests were done on a flow tek machine the #s are a bit off but these are only for COMPARSION purposes only I dont know the pressure drop of efficiencies of these units I also took a few pics of the difference between the spearco and the SS.
STOCK-410 CFM:3d_frown:
SPEARCO-770CFM
SSAUTO-870CFM
Like I stated earlier these numbers are a bit off the spearco is rated at 1080 cfm so the SS is higher than that I was not to surprised by the stock intercoolers results.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Nice! That's some useful information... now if only we had efficiency numbers as well... how would you feel about mounting temp probes pre & post IC, then putting each of these ICs on and running on the dyno?
Ya ya, I know, I'm wishing. :D
lintlars
ROOTS RADICALS
Ft.St.John BC
my old set up is the spearco/CT 60 trim when the car is going again it will be a bit different turbo/pipes/intercooler set up/intake so I cant just swap out intercoolers if I was retaining the same set up this would be feasable sorry.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
alright! nice researching. it's good to see people actually conducting tests instead of simply looking and making (uneducated) guesses from there.
