flooding problems on 87 7mgte
mk3junkie
46
grand rapids michigan
if the car dos not start within the firet turn it floods the motor and wont start.I puli the efi fuse and krenk it dry,put the fuse beck in and it starts ok runs ok .no codes any more the a/f ratio at idle is 14.6 and under boost is at 10.5 to 11.5 im boosting at 15psi low boost and 20 psi high boost.I just have the flooding issus.any help is good help.tx:1zhelp:
Another MkIII
697
Chicago
USPturbo89;1351862 said:
ummm well to start things off..... i dont think that a efi motor will ugh flood... but idk???
Its possible, if the injectors are leaking. I've seen it on a few Saturns and more recently my Dad's Ford. Try starting it while holding the throttle all the way open. If it starts up when you do that, I would do an injector balance test.
-AM3
Another MkIII
697
Chicago
mk3junkie;1352023 said:
no the temp is fine.what are u thinking?
I was thinking if it thinks its cold, it could be dumping extra fuel in for a cold start condition. If the gauge is always reading cold, an open in the ECT sensor circuit or a bad ECT sensor could cause that. But it seems like that's not likely. What about your fuel pressure?
-AM3
Another MkIII
697
Chicago
shaeff;1352062 said:
Are your injectors wired correctly?
Double check that, but I doubt that. It runs once he can get it started. So I was already doubting fuel pressure as well, but always good to check.
So far we know:
It is getting too much fuel
Fuel pressure is good
Injectors most likely are not leaking
It is not an ECT sensor related issue
I'm running out of ideas. I'll have to go research a couple things.
mk3junkie;1352068 said:
yes ther are the car runs when i push stardet and thet is the only way it starts.
Will it still start if you pull the EFI fuse and clear the fuel out, and then start it?
-AM3
Another MkIII
697
Chicago
mk3junkie;1352095 said:
yes if i pull efi crenk it fo 30 sec put it in it will start but not oll the time. the injectors are rc550cc
Check the cold start injector time switch. It is located on top of the T-stat housing, and has 2 wires going to its connector. Resistance should be as follows:
<59* F.............25-50 ohms
60-84* F..........51-59 ohms
>85* F.............60-85 ohms
-AM3
Another MkIII
697
Chicago
mk3junkie;1352482 said:
i just checkt the fuel pimp resistor operating resistens is 0.70 mine is at 0.00 ohms.ithink thet is the problem ill pick one up next weak and go from there
What, is that what we call gas station attendents now? LOL.
Hope that fixes it.
-AM3
mk3junkie
46
i dont know if it os gooing to fix it but im getting one on wensday so will see i allso chekt my solinoid resistor it is sopost to be 3 ohms my is showing 6.5 ohms.i am just going to replace it to and go from there
