currently the oil cooling setup in my car is as follows. its a 1989 NA supra. i have a permacool sandwich adapter with 1/2 in outlets going into this cooler
http://store.summitracing.com/partd...924500+4294888847+4294782888+115&autoview=sku
i have no thermostat in. and used non braided hose from permacool and barb fittings.
i am now putting in my turbo motor and am ready to step up and do this right. here is what i have come up with
i was going to run the outlet from my oil filter adapter to this filter mount mount
http://store.summitracing.com/partd...400006+4294851620+4294851462+115&autoview=sku
putting a oil temp sensor in one outlet and sending the other outlet to this thermostat
http://store.summitracing.com/partd...1070&N=700+400006+4294843279+115&autoview=sku
blocking the extra inlet and outlet ports. sending one outlet to the cooler i currently have which is linked above. then taking the outlet of the cooler back to the oil filter adapter on the engine.
i am going to plumb everything in 1/2 in braided which i think is -8 an line.
i need feedback on whether this setup is a good one or if i can put some better parts in here. thanks
