Help- ( sorry for the long post, trying to provide all the info as possible)
I dont even know how to approach this problem.
After finshing the engine replacement, the brakes, the steering, finally got the exhaust connected up, it was time to deal with the battery. I have been jump starting the car and the Altenator would get very hot when the car was running. I put a new battery in yesterday afternoon, started right up. When I hooked up the battery there was a large spark that arked between the battery terminal and wire connecting so I thought something was wrong right then. I ran the car for a couple of minutes shut it down and came back like 3 hours later. when I opened the door the light were dim, and the battery would not even turn the starter over :icon_surp .
Now I am thinking I must have a short somewhere, but how do I even start to find out where? do I pull all the fuses from the main box on the firewall then use a VOM to see which circuit is connecting to ground? If I fried the alt how can I test that?
I need some help in starting the diagnosis.
As always your help and ideas are appreciated!
Thanks
Steve
Thanks
Steve
