Hi all
I have a few questions now that my engine is back in the car...
- There's a coolant hose coming off of the bottom of the upper intake chamber (near the 2nd runner)... where does it go??
- There's two ring lugs coming from the wiring loom (i think :icon_conf), down towards the back of the intake manifold. I believe they are ground lugs and connect to the bolts by the 5th and 6th runners holding the intake chamber to the lower manifold?
- There's a square plug in the same group of plugs as all my transmission connectors. (A340) I don't think it was connected when I removed the engine, but I wanted to check.
- There's another plug coming from the wiring loom up near the 5th and 6th injector plugs. It is a brown plug with two red/black wires. I believe it was for the EGR vsv or the FPU vsv which have now been removed.
- Also wanted to make sure that the injector plugs alternate between red and silver plugs, starting with a silver one for the 1st cylinder and ending with a red for the 6th?
Let me know if you need pictures of any of these connectors/hoses/etc.
Any help appreciated, thanks.
Tom
Tom
