few questions
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
1. where did you guys tap into to get your a/f ratio for an a/f ratio gauge.
2. is there anything i need to know about when installing an aftermarket fpr. i know what i need to install it, but what should it be set at?
3. i already have my lexus afm installed and wanted to know if i should do anything else to make it work more effectively?
thanks, i just finished my rebuild and wanted to get things right
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
1: that gauge is useless, but you tap the blue wire on your O2 sensor...
2: simple install, nothing special, I forget base FP, but it'll change when you start tuning, up or down... I wanna say mine was tuned at 40psi base... But it was so long ago... Someone will correct me if Im wrong...
3: Theres nothing you can do... Its a tube... What could you do? Use a good filter, there's a start...
