ok so im burning oil, i need to change my CPS o-ring which will be soon, but could that be causing the car to smoke that much? i've changed the cam seals, there is a bunch of oil near the cams, some on the battery, some on the right tems cover, a bunch on the water pump and Tstat housing. i may be exagerating but there is a pretty good amount of oil in my engine. im pretty sure its not the cps oring causing that much, because watever drips outta that falls straight onto exhaust mani. and like i said before the cam seals were changed, and there seems not to be any "puddles" of oil inside the cam gears.
Any Know wat other seals/gaskets i should be changing or looking at?
Thanks,
emp.
Thanks,
emp.
