well i got my car running pretty decent, but im throwing a few codes. a 22(watertemp sensor) 24(inake air temp sensor) 32(air flow meter) 41(throttle position) i dont really understand whats going on because the only time it runs bad at all is on the first start up when its cold. once i get it started(which takes alot of cranking) it barely runs and everytime i touch the gas it wants to die. i think the reason for the hard starts is i may have not hooked up the cold start injector, but that wouldnt have anything to do with the codes its throughing and it running bad when i do get it started would it?
i cant get my timing to go below 14 with the terminals jumped, does that mean i have the CPS a tooth off? i just run out of flange when i try to adjust it.
also , can anyone explain or find me a write up on how to do a wheel bearing? i have one and i think you have to press it in? im not sure though.
and my starter grinds against the flywheel, do i shim it or what? im not sure how that works iv just heard of shims for starters.
i would go out and diagnois myself but im sick, so im trying to gather as much info first as i can. thanks for anyhelp!
