fast questions
supraturbo510
87 Silver Supra
Mar 11, 2006
23
Union City
planning on replacing my valve cover gasket ..want to know though will replacing this solve my issue with oil dripping on top of my spark plugs or is there anything else i need to replace..also coolant is being used up in my coolant resavoir pretty quik is this normal? i would fill it up to the full line and in 2 weeks it would be empty ... thanks
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yes. It should fix the oil dripping into the plug valley. Not much else can cause that.
I say it is not normal to loose coolant if every thing is working properly. You have a leak somewhere. Start looking at coolant lines and I would pressure test the coolant system for leaks. Hopefully it is not a BHG
johnathan1
Supra =
Aug 19, 2005
5,056
What ^^ he said about the valve cover gaskets.
As far as the coolant disappearing, that is definitely not a good sign...do you see any coolant leaking from anywhere? Or any on the ground after it has been parked? Does the temp. spike(overheating)? Any smoke out of the exhaust (after warm up)? Waterfall sound behind dash? Milky stuff under you oil cap, and on your dipstick?
If you answered yes, to any of the following questions, then it is likely a BHG...
supraturbo510
87 Silver Supra
Mar 11, 2006
23
Union City
i cant find any coolant leaks anywhere actually...the coolant in the radiator is always filled and never empty.. its just the coolant in the coolant resavoir goes empy pretty fast thats bothering me..i dont have any smoke after warm up too and the car driver great no overheating at all..
88YotaTurbo
658
Wolcott, Ct.
Same thing happened to me. All I did is keep adding collant and it stopped. So i'm guessing I had air in the system somwhere that had to work it's way out. Try running the car with the resivoir upto the full line WITHOUT the radiator cap on. This will work out any air pockets in your coolant system. once you notice the radiator isn't toped off and the level is dropping just add more collant until it stops.
isnms
United States of America
Oklahoma
i80.photobucket.com
but if you didn't fill the reservoir every other week, your radiator would begin to loose coolant too ;)
follow their advice, along with a compression test
