There are lots of factors to consider here before you should consider an electric setup based on looks or "free horsepower":
-Radiator type (stock or aftermarket)
-General condition of cooling system (and preferably and aftermarket temp gauge)
-Climate (Green Bay vs. Tampa Bay...ambient temps make a difference)
-Condition of charging system and battery
-Budget
The list could go on; I'm sure I didn't mention many points from the "Is it worth it" thread you found, Canadian; what I'm trying to make clear is that going with electric fans and making them work is more involved than just picking out the fans you want. It'll end up costing you significantly more than the price of the electric fan(s) alone--my dual FAL fans only set me back around $200-$220 USD, but the supporting mods from the list above to make me comfortable doing e-fans in the first place (especially in the mutant heat of Florida) easily set me back another $600-$1000. This included:
-Water temperature gauge
-Water pump
-Radiator & Cap
-All new hoses
-New OEM HG w/ ARP's @ 90 ft/lbs
-Programmable fan controller & wiring
Now of course, all items in the list (except the last item) have much broader benefits to the car's health. They should be checked and/or replaced if needed, especially before attempting any sort of cooling fan upgrade project.
If you don't know what to do Canadian, maybe try this--Try to think if there's anything else you'd want to do to the car with that kind of money. You could get a nice aluminum radiator, a brand new fan shroud and a replacement Turbo fan for less, and it'll cool better in most cases than an electric setup.
Hope this helps some...
EDIT: Also, from your first post Canadian--If your old fan clutch is in good shape, you may want to check the bolt patterns of the plastic fans to see if they match up. You may be able to swap over the undamaged '89 fan to your '87 fan clutch. Just a thought; it's probably your cheapest option.
