Fan for a 1jz with 2j water pump
S
Supracharged88
Guest
ok i got the IC and the m7 rad in what kind of ele fan will fit and keep the engine cool. i hear of some ppl using fans from a Ford Torus, if so what years. also what AM fans can u guys suggest.
Thanks alot car is almost done!!!!
EvoLuTioN
no-JZ Your Mom!
Mar 10, 2006
508
Bed
why not use the stock clutch fan, since you swapped to a 2JZ-GTE waterpump, then you're already preped for using a clutch fan, it'll do better than a electric fan and less prone to failure
JustinGotA1j
532
Chilliwack
Im running a set of Flex-A-Lite 210 Dual 12" Puller fans. They have worked great for me so far and didn't cost too much. I see them for sale on the forums sometimes to so keep an eye out.
Freshmaker
396
Oconomowoc, Wi
I just got a Taurus fan from a junk yard. I need some mounting hardware yet, but its a tight squeze. The shroud won't fit in unless you trim some back.
I still need to mount a temp-switch in for my control circuit.
daneyan
441
South Florida
get the fans from i think the 89-97 maximas they work with a little shaving not much, or the fans from the dodge intrepid, really nice fans and kick out a whole but load of cfm's and are almost as thin as flexalites, 94-97 nissan altima fans work as well with a little shaving.
Freshmaker
396
Oconomowoc, Wi
Just got my Taurus fan working. I am using a control circuit from a local auto parts store and I only wired in the low setting on the fan. So far it works great!
I let it idle for about 20 min with no problems. Then, I did some hard pulls and let it idle for 5 min and still no problems. This was all in 90* weather :)
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
fal fans and a autozone 180* switch here, motor stays under 50% on the guage at all times. (even after 1.5hr drives)
