fan clutch removal from water pump?
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
i cant figure it out guys, what exactly do i have to do? do i need to open up the fan clutch itself? if so i stripped one of the bolts and im gonan be angry, countersink ftw! any help is appreciated.
oh and i checked tsrm and searched, doesnt show it.. :(
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i found if you are spining the pump on the belt and cant break them lose, grabe another 10mm and use i across from the one your breaking lose, go all the way around, and by the time you break the last one lose it takes alot less effort to untighten one of the lose ones you had to put the wrench back on to break the last one lose..
hope that made sense..
Oct 11, 2005
3,816
Thousand Oaks, CA
Before you do that vice grip thing, try using a 10mm box end wrench. It's a tight fit but you can get one on if you jiggle around the wrench. If you use an open-end wrench you will round the bolts 50% of the time.
Mr.PFloyd
Jun 22, 2005
3,964
kk update guys. car is runnign again woot woot! But the pump is leakign a bit from the top cause my torque wrench is broken and ill go buy one tomorrow. whats the torque raring 0on the bolts for the water pump? Thanks in advance.
Doward
4,245
Alachua, FL
You lost me here... how is your pump leaking because your torque wrench is broken?
If it's leaking, just tighten it a hair more. My torque rating on water pump bolts (after cleaning ALL THE THREADS OUT <-- important step people ignore) is hand tight + 1/8 turn.
If everything is clean between the gasket mating surfaces, with a new gasket, it does not take much preload to hold everything together nicely.
Mr.PFloyd
Jun 22, 2005
3,964
im sorry, the pump is leaking between the gasket and the block, and i dotn ever overtigtne my bolts because i am never sure and i do not want to break a bolt inside there. It is leakign a bit because of this. Not a big issue but im sorry i have to exzplain better sometimes >_<
Mr.PFloyd
Jun 22, 2005
3,964
okay, so now my belt is sweaking somewhere inside the bay. does it mean i put it on too tight, or can it be because of my bearings being old or the pulley being unbalanced for some reason? Any help is appreciated..
