Hello everyone, i've been lurking for awhile, thought i'd join in the fun, I have a White '87 Supra N/A daily driver, and a Red '87 turbo, targa, got it for cheap, barely drove home, tore it apart, bhg between 4 cylinders and a bunch of water jackets (pictures @  http://www.mkiiitech.com/forums/viewtopic.php?p=4147#4147 )
This is regarding the '87 with about 145k miles on it now (still running strong)
I've been running Royal Purple 5w30 for 2 oil changes now
I had some signs of a possible BHG, radiator overflowed once, waterfall sounds, occassionally abit of a spike in the thermostat... heater only blows warm at revs.
I replaced my radiator cap and burped the system (was unsure if the hill was steep enough, steep but not extreme), no more waterfall sound, heater still acts funny but alot better, and i saw abit of a spike on the thermometer on the freeway in stop and go traffic yesterday. Also the VSV works with the climate control just fine, goes all the way up and down. I noticed theres a leak sound coming from a white flush/purge cap on the radiater hose going from the VSV to the cyl head when i shut off the car and got out
I did a compression test, i didn't write down the results but this is real close:
Cyl 1: 165 psi
Cyl 2: 165
Cyl 3: 163
Cyl 4: 160
Cyl 5: 150 (shot up to 200 with abit of oil)
Cyl 6: 165
So it appears as though my rings are fading, the question is, could i still have a BHG? (i'm guessing yes) the other is, should i change back from synthetic or will that cause more problems (i lose about a qt. every 3,000) Should i just get something thicker?
Cyl 1: 165 psi
Cyl 2: 165
Cyl 3: 163
Cyl 4: 160
Cyl 6: 165
