Factory Anti-Theft System
MKIII88Supra0518
High Point, NC
Ok so i bought my car off of craigslist and it did not have a factory radio or a radio at all. And i noticed that the supermoniter did not work either. So i bought a radio from best buy and wired in the radio. I plug it up turn on the key and it does not work. I go and check to see if the fuse it blown and there happens not to be a fuse in there at all so i put a fuse in it and the radio works and so does the supermoniter. So i think its all nice and dandy. I lock the car when i get home i go to get in it the next morning i put the key in the door and the alarm goes off and i get in the car put the key in and turn it to get it to shut off. And low and be hold it wont start. So i have to take the fuse out that controls the radio and the SM to get the car to start and disarm the alarm. i want to know how i can disarm it with out taking the fuse out i want to be able to use the radio. Can someone please help me even if there some wires to cut i will cut them or just tell me how i can unlock the car and not set the alarm off.
-Josh
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Once the alarm has been been triggered the starter won't work until the system is reset. Try using the passenger side door lock to do that.
You basically have two choices:
1) Defeat/disconnect the system and bypass the starter interlock. There are a few ways of doing this.
2) Fix the cancel switch in the driver's side door lock. It's why the alarm went off in the first place.
